Window shows up behind the existing window
Today I had the strange situation that the view window and all the other windows showed up behind the open window of wd. also other software was doing that and I could not close the frontwindow, not even move it. at the end I had force a stop of the wd software ctr alt del and start it again. now no problems. something in a setting (XP?)
gerard
It is happening with me with the latest version still 10.37d-B17. I found if I had a Control Panel sub-edit window open plus the webcam exe running, and perhaps Explorer open, then going from one to another and back to the WD task bar icon, the Edit page disappeared and the WD main page was showing again but it was not active.
A trick I found was to keep Task Manager alive and then select it, and then Minimise it and then the live Edit page came backā€¦ :shock: :slight_smile:
TokKiwi
