Wind Gusts only been recieving
I have not recieved any average windspeeds for the past while. All I get are the gust windspeeds. This is rather apparent when I go to weather underground and look at the graphs there, and also the normal graphs WD produces are all blocked in and are only showing the gust wind speeds.
for your weather station type, the data logging system only has 1 windspeed:
average…
WD then comes up with a gust that is the maximum of the average readings from the data downloaded…
is with the ws2010 or the ws2500?
(your profile says ws2500 but i never know which station you are refering too)
hehe Sorry Brian… I have the 2010-13 data logger connected to the system… but I also have the 2510 instruments… I think thats where the confusion is.
These are the sort of graphs that I am getting due to it. It also means that all i get is Calm for my wind speed readings.
It should be white underneath the red there. It used to be there. I am using version 10.15a
try ticking, show gust at cursor position, in the graph setup
(i guess that should be on by default for your station type)
