Noticed for a while (now on 9.96a) that on the main WD panel display graph how the average and gust wind speed graph is not constant. Now is it me (stilllearning) or is it a oddity??
The graph shows a peak gust in red at 12:00. So I watch the graph display, suddenly the peak disappears,then sometime later it’s back. One minute later it changes colour, then a minute later it’s gone again.
It’s definately cyclic and watchable. Every minute it appears the graph(and I only monitor Gust & Average wind speed) changes, not only peaks dispappear but the averages actually seem to change, then a minute later change again back to original.
Ah just watched it again, it appears that the wind gust & average data actually changes, places where there were wind gusts disappear one minute and then some other data is shown and then the original re-appears next.
I am monitoring over a 24hr period, on the graph
Q,
I believe what you are seeing is the graph updating on the even and odd minutes. On one update it displays the even and the next the odd minutes data.
John
Q,I believe what you are seeing is the graph updating on the even and odd minutes. On one update it displays the even and the next the odd minutes data.
John
John
Thanks for that, like I said I’m still learning, that would explain a lot of things.
Much appreciated.
John
John
Much appreciated.
