Wind graph way off
Brian
The new wind graph (in normal scale) is off by about 50%. A reading of 15 MPH (on the half scale, which is correct) shows 30MPH on full scale. It could be because “full scale” is 0 to 100MPH and “half scale” is 0 to 25MPH (which is really quarter scale)… so maybe it’s just a matter of renumbering the scaling.
Keith
Where are you adjusting this scale? I am confused, which is not hard to do. Is it in normal scale by default? How do you go to halfscale? Are you talking about the wnd graph on the main display?
Rupp
It’s under “Graph Setup” on the main screen.
Brian: Did you get a chance to check this out?
Keith
Brian
Using 9.60a wind graph is off and it keeps fluctuating whenever I set it to half scale the scale, numbers remain the same but the graph lines reduce in heigth by half. Also we had a gust of 25mph and the graph high peak keeps fluctuating between 20 and 25 mph…Strange
also I know you are probably trying but lunar set time is still off by 45 minutes…
Jon
Brian
Seeing the same thing here on the wind graph in ver9.60b
Keith
