Wind Distribution Errors
While viewing the image it does not appear to be up-to-date, and I am getting errors in the programerrorlog.txt file:
ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:00 10/06/11 ERROR: Access violation at address 004056C0 in module 'WeatherD.exe'. Read of address D0E82824 at time/date 08:01 10/06/11
Add:
Within a couple minutes WD disappeared. No message, just gone. Realtimeftp was still running.
just tested here , view, wind distribution
no errors, no problems
not sure why you have this problem
no other reports of this problem
could have been a memory issue of some sort, and the debug version might have shown something
does restarting fix it?
i.e does it occur again, this error?
Unable to duplicate. I noticed the image is not updating at http://travelingrvwx.com/wxtrends.php so I went into WD to see if the image was current. I clicked on dir/spd and then 12/24 hour and nothing happened. It was then I noticed the errors.
