Wind Dial not changing to 50 MPH
I just had a wind gust of 40.3 MPH and the graph moved from 0 -25 mph to 0 - 50 mph. The wind dial however did not and is still showing a max of 25 mpg. As I set here and watch it the readings are 27.5 and the dial is pegged at 25 MPH.
you will most likely have ot over ridden under setup, units…me thinks
Brian, I have not touched any of those options.
Force the wind dials top reading to this number = 0
Wind speed on graph scale lift factor = 0
you can increse it via the toggle switch on the weatehr dials
but it should auto adjst…
