Wind chill reading wrong
Hi there ! :slight_smile:
My windchill readings is +24.7 degrees Celsius, but normal temperatur is +18.8 Celsius.
This misreading is in the summary.gif and on the tabel at my website.
Anybody else whom has notice that ?
Best regards Knut/LA9QFA
Hi ! :slight_smile:
It’s look like the winchill temp is mixed up with the heat index.
This two numbers is showing the same value all time !
I’am using version 9.81
Knut/LA9QFA
yes, i made some changes there (improved overall)
please use verison 9.81d
Hi Brian! :slight_smile:
Sorry, no change with the latest version 9.81e.
Windchill is still incorrect!
Knut/LA9QFA
wherabouts?
(note, I did upload a new 9.81e, so please try a new download)
The windchill display in the summary.gif!
Normal temp says 18.3 Ceslius
Windchill says 25.3 Celsius
How can windchill temp be higher than the normal temp when the wind blows.
I am using the latest update, do I misunderstand something?
Cheers
Knut/LA9QFA
it should say heat index you see…
i thought i had that working…
hummm
i will have to force some numbers into a test program (as its winter here)
ah ha
i had it working fo oF only
uploading a fix for oC now
(normally its the other way around, LOL)
Hi Brian! :?
Now I am really confused!
I just check my website and now the windchill display is correct.
I must admit I have losed my controll on what’s is happenening now.
Tomorrow is another day, I’l take a new check at daytime then.
Cheeers
Knut/LA9QFA
a new 9.81e is ready now
what happens is the windchill should (and will now) change to heat index once aobe 17oC for the current temperature
Hi Brian! :smiley:
Fine, you make it this time.
Looks ok now at the web.
Many thanks for good support Brian!
Cheers
Knut/LA9QFA
