What happened to Time numbers on X Axis?
I haven’t been keeping my version of WD up to date, and today I updated across a bunch of releases. The main difference I notice is that the numbers for the time of day are not displaying along the X axis of the graph. Can I get them back?
Lane
go to setup, graph setup, and untick, time from cursor instead of hour plot on temp/hum graph
try that
but it also depends on what version you were using, and that I migth have a new time format file…but it should start repulating from now on
Thanks, I was just too impatient. The program started with no hour numbers, but after a while they started to appear. I’m using 10.20i.
Lane
it will be becuase i now have 3 day recording for the hour numbers instead of (originaly) a much shorter time…from memory ,.so a new file format got started with the upgrade you did…will be ok from now on
