What happened to the Baro graph?
Yesterday everything was fine and wonderfdul as I discovered the graphine button in WDL.
There were quite a few graphs available today there are only a few - what have I done, or not done, to lose the barometer graph from WDL?
Cheers
The 24 hour graphs are part of the clientrawextra.txt file. If that doesn’t load correctly then the graphs don’t appear. I would expect your clientrawextra file to be at http://www.computersforcharity.org.uk/weather/clientrawextra.txt but that’s just giving a 404 at the moment.
Julian
Thanks for that J
Can you tell me where it sets the upload time for clientrawextra.txt please. I seem to remember seeing it was set at 6:00 am when the computer is not always on.
Cheers
which versiion of WD are you using?
as it shoould get created every 10 minutes and uploaded every 10 minutes automaticly with clientrawrealtimeftp.exe program
(make sure you get that updated with the latest downloads of wd ( i.e exit it first )
I’m using WD 10.17 Z and WDL 2.05
ok,so, do you have the clientrawrealtimeftp.exe program in use?
(enable that via setup, control panel, webfiles/web page setup, real time ftp setup)
but make sure its a recent version (i.e you need to exit it first before installing the latest FULL version of WD (and not just a zip version), so that .exe can be updated…maybe thats the problem?
(it needs to be vers 2.8 or latter, for the clientrawrealtimeftp.exe) (double click the icon in the system tray to bring it up so you can see the version number)
Now things start to get complicated…
I have clientrawrealtimeftp.exe version 2.90 and
I have clientrawrealtimeftp2.exe version 2.80 but when running shows 2.70 and
the ftp2 version has an error with the wrong IP address for my FTP but I can’t find any reference in the Setup to change it. Should it even be there?
you should not normaly need to be running the clientrawrealtimeftp2.exe program…
(that is for a 2nd ftp server)
i will check though and update that one to make sure it upload the clientrawextra.txt file
check your settings in the real time ftp setup (see under webfiles/webpage/real time ftp setup)
Installed 10.18C this morning ahving left WD running overnight and everything seems fine.
I still can’t see any reference to the clientrawextra.txt file though in the setup live weather page, must be eyes or summat:)
Cheers
