The pointer on a dial blinks from red to green repeatedly?
The wind speed graph has green traces? (I assume blue is steady and red is gust).
Just outside the upper left of the windspeed graph there is a green scale numbered from 90-115? (max gust on graph is 15 mph). Sometimes its just a block of tiny dots.
On the “Weather Dials” window, I push the rocker switch to the left of the “Current” dial either up or down and it changes the scales of the “Current” and “Average” dials, but just momentarily?
I see a “cloud base” shown? Is this coming from the Metar or is it being estimated in W-D?
Larry
Green is low wind speed
That is estimated in WD by the humidity leave, higher humidity, lower cloud base.
3. Just outside the upper left of the windspeed graph there is a green scale numbered from 90-115? (max gust on graph is 15 mph). Sometimes its just a block of tiny dots.
I amnot sure where this is…can you post a screen shot?
thanks
that rocker switch is a bit of a relic, and i guess I should remove it, as you can set the maximum dial scale in the units setup now
I’m ignorant about “low wind speed”. It never was an item on previous software. I’m guessing that is the lowest speed recorded during the measurement period. True?
Is there a definition for “gust”, etc someone can point me to?
I have sent you a screen shot in response to your request of Thu 19 Aug 2004 2354.
The original question was
“3. Just outside the upper left of the windspeed graph there is a green scale numbered from 90-115? (max gust on graph is 15 mph). Sometimes its just a block of tiny dots.”
Sometimes it looks different, and might actually be 2 separate blocks. If it isn’t showing, changing any screen colors seems to bring it back. It usually goes away after a while, but returns periodically.
