Webfiles/page setup
In the above section (found in setup/setup web files etc) how do you set up the following:-
  1. How do you display “show the time of the next update”. I have ticked the box to display this, but this does not show the web table page.
  2. What is the blank field used for where it says “Special Status Message”
  3. When you go to “view web page”, what is the “select file” radio btton used for? Is this for selecting a background image?
show the time of next update is on by defaul;t, and it appears in the top of the default web table
special status report:
it appears as a scrolling text line above the default web table
use for it special weather warnings or similar
Q 3:
it lets you view any other .htm or .html file on your pc
it could be anotherr WD generated web page, e.g the weekrep.htm, or a custom web page, wx.html, or any other you like
“show the time of next update is on by defaul;t, and it appears in the top of the default web table”
Mine doen’t Brian. Is it because I don’t let WD to FTP?
i think its becuase you are using the customise inernet and file creation, and have that set to every minute?
