In the tips section I introduced the sequence to setup my webcam.
Here is the tip:
Disable webcam
Restart WD
Check WD has catched the correct webcam driver.
Introduce a “space” in jpeg file location (the greyed file name area becomes blank) then select the correct file location and name.
Introduce the correct file location and name in gif file field
Save
Choose the gif file to animate and upload.
Start and keep alive in the bottom of the frame.
Save and Close.
Start floating Window
Then Start Streaming asf video. Save and close.
Ontil version 1020o, it was working.
But the following version until version 1020x, it doesn’t work. I found out the webcamimage.gif and webcamimagejpeg.jpg are NOT generated.
Do you have the same problem?
Thanks. #-o
Cheers.
ahhh
just becuase the gif and jpg names are not in the box, that does not mean wd does not remember them when it is restarted
(i.e you will not need to re enter them (I dont!))
but i will fix it so they are shown again in that file save settings screen in the webcam capture setup
Tried version 1021a and the gif and jpg files are not created. Going back to version 1020o. #-o
Why do you have a field with the jpg file and not gif file (on the left of the window) in the setup webcam-save file tab?
Tried version 1021a and the gif and jpg files are not created. Going back to version 1020o. d'oh!
i am using 10.21 a
no problems here with the web cam file creation
the left hand jpg name is the primary file name created used by the web cam capture /…I will hide it…
its the same as the one you set with the set the jpg file name and location…which is the key …you need to have that set correctly
