Webcam night Tag doesn't work
So I have the following line in my wdlconfig file:
            <url>http://www.fiamingofamily.com/evatun/weather/webcam.jpg</url>
            <urlNight>http://www.fiamingofamily.com/evatun/weather/earthmoon.jpg</urlNight>
            <caption>EVATUN WEBCAM</caption>
            <refreshRate>120</refreshRate>
            <embedded>1</embedded>
            <x>5</x>
            <y>35</y>
            <size>40</size>
            <linkUrl></linkUrl>
            <title>Webcam at EVATUN</title>
I have also setup the correct Lat & long. Does this make any difference to the clientraw file? I noticed the sunrise & set times on WDL were set with Lat & long on 0.0.0 & 0.0.0.
Anything else I need to look for?
You need to make sure that the lat and long are correct in WD because WD uses that info to send a day / night flag to WDL.
You can use the clientraw parser http://www.tnetweather.com/wd-parser.php to check that the flag is correct - item 610 in the clientrawextra section.
Julian
Right now, night time there, the 610 day/night flag should be ā€œNā€ but is showing -100 and the ā€œNā€ is shifted to field 614.
This data in the wrong fields problem was reported WD in bug reports today http://discourse.weather-watch.com/t/20365 and per Brian is fixed in the latest zip version http://www.weather-display.com/downloadfiles/WeatherD.zip
