Webcam image on a different location
Is it possible to put the webcam image on a different location . I want to upload it to the web server so I can put in a different page. Now it is uploaded in C:\wdisplay\webfiles
if you are using the direct capture of the web cam image in weather display, then you can set the location that the file is save to (and the filename)
try that
or if you are using the 3rd party web cam setup, you also set the location for the file (web cam file destination)
Thanks for replay, what I mean is that I want to ftp it with WD. So is it possible to upload it with wd and what do I have to fill in instead off C:\wdisplay\webfiles\webcamimagejpeg.jpg
ftp:
in the setup, control panel, web cam setup, top most button, click on that (to select the web cam file)
then in the setup, control panel, ftp/internet setup, web cam , and there set the times and also select that web cam file too
and under connections in the ftp setup, set the ftp server details, and turn on the main internet switch
