Web Files not updating when I change parameters from the control panel
Hello again. Thanks to everyone for their previous help. What is happening now is that when I want to change the way the web page looks (I am not using custom web pages but the ones generated from the program), things just aren’t changing. I want to show graphs with the screen capture but that doesn’t seem to work on the fly. When I change things, for example, add a table or take things off, they don’t update on the web page. In some cases, I can go to the Internet File Creation screen and force an update. I’m sure that there are some basic things I’m not doing properly, because sometimes things work and sometimes they don’t. If there is a FAQ or other place that has this info please let me know and I’ll search there. Thanks in advance.
The web page generated by the WD program uses three files found in the wd\webfiles folder - datahtm0.txt, datahtm2.txt and datahtm3.txt - to generate the web page. In the WD control panel, when you click on the “web files/web page/realtime ftp/wdl” icon, in the screen that opens select the tab “web files setup #1”, and near the bottom in the web table/html box you’ll find check boxes that will tell wd that you want to use custom tags added to datahtm0 or datahtm3, and/or let you manage the datahtm0 or datahtm2 files. Once you’ve checked the appropriate boxes, you can add/delete lines from the appropriate files to add or remove things. You’ll also need to be sure to tell wd to upload the graphs, etc. to your host site.
Thanks. Yep, I’m figuring all this out.
