WD 10.19f zip
How long should I wait for the web cam image capture to work after WD startup?
I am using the older method as the new method also failed to capture. The image on the capture setup page is so large it covers up part of the display options.
Logtech QuickCamPro 4000,
Capture,
Major Type Video-Sub Type:RGB24 Format: VideoInfo RGB 640X480, 24 bit
Update every five minutes ticked.
Reset after restart of Weather Display ticked
Use older method ticked.
what you need to do there, with the new capture method, is then resize the raw image size, with the spin buttons for wodth and height
can you still see those?
the other thing i can do is check if it has autosized too large, and then force a resize of that capture window
the only thing changed after 10.18x is that i now have it that if you have ticked , to reset after restart of weather display, then it will reset the web cam capture....but only the new method,....so if you are using the old method, then that will most likely stuff that up...
so, try, unticking that, or try using the new method
(and I wonder if this change I made is causing some of the other problems people are getting since 10.18x (ithe solution is for wd to check if its old or new method, and which method to reset at start up
