WeatherFlow UV
try downloading again
http://www.weather-display.com/downloadfiles/cronweatherflow.zip
i have added a log at the bottom
re the history data from a tempest, testing that now…seems there is a difference between the tempest the original…working on a fix
I got the history data working from Tempest data now, whew
just need the rain to be tested from history data
Brian
"weatherdisplaytest looks good. I did a test data extraction and it’s working correctly - THANKS. I’ll verify it in the morning when I restart the computer.
Latest “cronweatherflow” works correctly 1 out of about 5 tries. When the upper left hand box just show “OK” then there is a GREEN LED and everything is correct. The other 4 out of 5 times the box in the upper left show OK, followed by “Remote Host connection complete” and “Web socket connection complete” with a RED LED, but the data is all showing correct on the screen and in WD.
I can’t explain it.
MikeyM
Is with the station ID set to your tempest station?Data from the web socket…u will see the OK top left show etc
If the data is from a tempest
Then the UDP data can only
Get ingested if that data has tempest data
The raw udp data and debug about it shows in
The new bottom pane
It’s a shame weatherflow never provided me with
A tempest despite promising me they would
Yes, it is a shame. Wish I had a spare to ship down to you. Maybe I can ruffle their feathers by mentioning how much more help you could be to Weateherflow users if you had a Tempest and mention it might really help their sales.
MikeyM
Brian
Data extraction worked perfectly this morning and I just tried it again with a minor shutdown of about 15 mins and perfect again. Thanks!
MikeyM
good news
weather flow is sending me a test kit Tempest! :slight_smile:
Good News :slight_smile:
Maybe MikeyM and others shook the trees enough :wink:
the delay was more that it has taken them time to get consents re radio frequencies for this part of the world I think?
