I am running “Weather Display for Linux console 64 bit Linux desktop Version on 30 August 2021 - 23:45:03”
But i cant find the correct way to write the line/settings for weatherflow tempest ID in the config.txt file.
When runnig wdconsole and the cronweatherflowconsole starts. it produce file weatherflow0.txt weatherflowip.txt
inside weatherflow0.txt the device ID is 27100 and inside weatherflowip.txt the device ID is 87155
and it is not my ID.
in my config.txt the line is "Weatherflow station ID="and my ID
even if i remove the line. it still give wrong ID in files.
So how shall the line in config file be written
humm
there should be an entry in the wdconsole.ini
[Weather Flow]
stationID=
is that not there?
and in the config.txt
there should be
which should be set (when you change the default station ID) via the config.html (when you save the settings then copy across the saved config.txt to the downloads folder to where consolewd is running from (then restart that)
Yes the wdconsole.ini file is there, and the entry in the file is there.
But it does not set any ID in the wdconsole.ini file.
It is exactly
[Weather Flow]
stationID=
The config.txt file has the line
Weatherflow station ID=“and my number”
I tryed to set the ID in the wdconsole.ini file manualy. But when i restart the program it just set it back to nothing.
It seems like the consolewd does not make the wdconsole.ini file, with weatherflow ID from config.txt
config.txt
Weather station type=72 Weatherflow station ID=***** [color=green]"My ID from Weatherflow. 5 digit"[/color] meteobridge username=--- meteobridge IP=192.168.0.36 meteobridge password=--- Comport number (e.g 1)=U Comport custom= Revb Davis VP=N Davis rain gauge=3 Davis com method=1 Davis timeout=0 OWW file location=--- Davis VP IP port=22222 Rainwise ip=192.168.0.23:80 Davis VP IP address=192.168.0.23 Davis WLL IP=192.168.0.13 GW1000 IP address=192.168.0.15 wh1080 read delay=50 latitude=**.**** longitude=**.**** Station name=************** clientrawlocation= Start up daily rain(mm)= Start up monthly rain(mm)= Start up yearly rain(mm)= Do wunderground=N WU realtime=N Wunderground username= Wunderground password= Wunderground timezone=-5 timezone=0 Direction offset (whole degrees)=0 Barometer offset(hpa)=0 Do metar=N Metar name= Do metar hum=N Do mysql=N Mysql username= Mysql password= Mysql server= Mysql databasename= Mysql tablename= Mysql metric=Y Mysql time=300 Do CWOP updates=N CWOP station id= CWOP ham call sign=-1 CWOP Latitude= CWOP Longitude= wmr200 data read delay= Do clientraw FTP=Y FTP server=***.***********.** FTP username=*********** FTP password=********** FTP port=21 FTP remote dir=/*****/*******/*******/ FTP use curl=N FTP use passive=Y FTP use remote file rename= FTP time interval=3 FTP use curlssh=N FTP the custom file=N Save logfile=Y Logfile metric=Y Create custom file=N Use this filename instead of wx.html= Use this filename instead of wx2.html= Use this filename instead of wx3.html= Use this filename instead of wx4.html= Use this filename instead of wx5.html= Temp in celsius=Y Wind in=m/s Baro in metric=Y Rain in metric=Y run cron files=Y do custom log=N custom log out=customlogout.txt temp offset= hum offset= wmr300 channel number=1 Rain Offset=0.0 Modified rain gauge= update WOW=N WOW id= WOW pass= update PWS=N PWS id= PWS pass= Do windycom=N windycom station #=1 windycom API key= create wxnow.txt=N update windfinder=N windfinder id= windfinder pass= update meteotemplate=N meteotemplatepass= meteotemplateurl= meteotemplatefast=N meteotemplatefast2=N universalupdaterate=2 Do weathercloud=N weathercloud ID= weathercloud KEY= Send Email=N Send hour=6 Email minute=10 Email server= Email user= Email pass= Email sendto= Email from= Send Email hour=N weatherlink.com DID= weatherlink.com API= weatherlink.com USR= weatherlink.com PASS= ultimeterrainmetric=N ultimeterrain0.1inc=N ultimeterrain10=N Ambient API Key= Wunderground API Key= Wunderground API StationID= Wunderground API updaterate=300 Wunderground API use time=N Use Davis Air=N Davis Air IP=
wdconsole.ini
[meteobridge] user=--- ip=192.168.0.36 pass=---[Davis wll]
url=192.168.0.13[GW1000]
IP=192.168.0.15[Connections]
customclientawlocation=
FTPTime=3
FTPUsername=**********
FTPPassword=**********
FTP Port=21
use passive=yes
use curl=no
use curlssh=no
FTPHost=*************
RemoteDir=************
RemoteDir2=[Metar]
name=[Mysql]
server=
username=
password=
databasename=
tablename=
time=300
port=
metric=yes[Aprs data send]
station id=
WD version=8.0
ham call sign=-1
latitude=
longitude=[Davis Air]
IP=[Weather Flow]
stationID=[FTP Custom]
ftp custom filename=wx.html
ftp custom filename2=
ftp custom filename3=
ftp custom filename4=
ftp custom filename5=
ftp custom=no[customclientraw]
updaterate=5
File weatherflow0.txt is made with wrong location ID and station ID (it use ID 27100)
File weatherflowip.txt is made with wrong device ID (it use ID 87155)
File weatherflowdata is correct
copy lines from running consolewd
{"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648747,4.29,222]} {"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648750,4.55,205]} {"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648753,3.02,215]} {"serial_number":"HB-[color=green]CORRECT SERIAL[/color]","type":"hub_status","firmware_revision":"171","uptime":2985971,"rssi":-62,"timestamp":1651648754,"reset_flags":"BOR,PIN,POR","seq":298383,"fs":[1,0,15675411,524288],"radio_stats":[25,1,0,3,4725],"mqtt_stats":[621,20]} {"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648756,3.83,214]} {"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648759,3.62,200]} % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 2019 100 2019 0 0 3293 0 --:--:-- --:--:-- --:--:-- 3293 [color=red]Device ID 1 =>87155<[/color]= {"status":{"status_code":0,"status_message":"SUCCESS"},"[color=red]device_id":87155[/color],"type":"obs_st","source":"cache","summary":{"strike_last_dist":10,"strike_last_epoch":1648002617},"obs":[[1648188660,null,null,null,null,300,996.1,null,null,2879,0.44,24,0,0,0,0,2.13,1,1.041035,null,null,0]]} Barometer 996.1 Uv 0.4 hail 0.0 Battery2 2.130 Solar 24.0 % Total % Received % Xferd Average Speed Time Time Time Current Dload Upload Total Spent Left Speed 100 281 100 281 0 0 513 0 --:--:-- --:--:-- --:--:-- 512 {"serial_number":"ST-[color=green]CORRECT SERIAL[/color]","type":"rapid_wind","hub_sn":"HB-00031233","ob":[1651648762,3.18,202]} {"serial_number":"HB-[color=green]CORRECT SERIAL[/color]","type":"hub_status","firmware_revision":"171","uptime":2985981,"rssi":-59,"timestamp":1651648764,"reset_flags":"BOR,PIN,POR","seq":298384,"fs":[1,0,15675411,524288],"radio_stats":[25,1,0,3,4725],"mqtt_stats":[621,20]}
if i edit the wdconsole.ini file and add ID to the weatherflow section and ONLY runs cronweatherflowconsole. Then it reads my weatherstation with all parameters and use the correct ID’s.
and all files is then correct
I have now also tryed installing Raspberry PI 3 with “Weather Display for Linux console 64 bit Raspberry pi3/4 with 32 bit Operating System Version on 24 January 2022 - 20:46:39”
but this also wont read the ID from config file. is the config.html making the variable inside the config.txt wrong. or is it that the consolewd dosent read the variable and set it in wdconsole.ini?
Linux version, running on server: Weather Display for Linux console 64 bit Linux desktop Version on 30 August 2021 - 23:45:03
Pi version, running on pi 3: Weather Display for Linux console 64 bit Raspberry pi3/4 with 32 bit Operating System Version on 24 January 2022 - 20:46:39
Same output on both system
Device ID 1 =>87155<=
{“status”:{“status_code”:0,“status_message”:“SUCCESS”},“device_id”:87155,“type”:“obs_st”,“source”:“cache”,“summary”:{“strike_last_dist”:10,“strike_last_epoch”:1648002617},“obs”:[[1648188660,null,null,null,null,300,996.1,null,null,2879,0.44,24,0,0,0,0,2.13,1,1.041035,null,null,0]]}
I know that the device_ID and station ID is not the same.
But device_ID is for station ID 27100 and not for My station.
and the wdconsole.ini does not have any id in section for Weather flow
this has been fixed now latest update #-o
