I noticed when I put together a custom weather report that the following tag %VPextratemp1% for extra temperature sensor 1 . It works, but the value is metric. is there anything I can do to turn it into F ?
ah, i see the problem
i had a double up in the code…
it first set it correct, and then went and stuffed it up further down the code
(it pays to do a search again)
uploading a fix now as a new 10.15z
will be ready in a hour or less
I appreciate it. I thought for a moment the metric movement was back, lurking in the corner.
Actually, the cable went out so my emails are trickling in but so far WD hasn’t had another crash so we will see.
