Weather Underground stopped working July 1
I just noticed that as of June 30th around 9pm my weather underground stopped getting data. All my historical is there.
I have made NO updates to either MacOS or Weather Display
Did something happen to the site? I thought I found that maybe I need an API key now? If so I tried to create one but it gave me a whole new station ID.
I would like to get my original station to start working: KGAATLAN16
Not sure where to post this, so trying here.
Any help would be greatly appreciated
WU is changing gradually from
station-ID and user-login-password
to
station-ID and station-key
Check your settings in WD, maybe that is the problem
See screenshot to find the items.
There is yet another problem. I tried to login to WU but said i had no valid email. I created a new login. Then in the screen you are showing I had no info, so I added a device, which is what gave me the new Station ID
Interesting also in WD, I did a test send and it shows up on my station but won’t feed after that
How can I get my original station ID to start working
Where do I put this key into WD?
This is the WU setup in WD (unless Brian needs to update that)
You should use your original e-mail address you always used and the original password.
Check for extra spaces, a capital fierst letter , and so on.
WU does not check if your e-mail still exists, it only checks if you are using the same e-mail address as last imt.
If you are logged in, you can use “member” → “settings” to change e-mail and password.
I am not familiar with WD, but to me it seems that nowadays the “Key” should be in the old “Password” field.
I thought about that. I tried “recover” password. When I put in my email It said it did not exist.
VERY ODD
Thanks for your help though
