Hi!
the clientraw file is on here: https://www.meteobellvei.cat/clientraw.txt
Thanks antonio!!! 134 / 5.000
Thanks Antonioā¦weāll wait for newsā¦on my server they already announce availability for version 8.4ā¦which I havenāt installed yet.
Luckily itās not a PHP 8.x error
Seems a setup problem in your setup.php for $configs["bgURL"]
That line 21 should read
'bgURL' => "blue-sky.jpg",
it reads now something like
'bgURL' => "../stickersPWS/backgrounds/blue-sky.jpg",
Can you check?
For those who love to debug:
That āinvalid image iconā looks like nothing, but one can read the hidden text in it using the inspect function of your browser, in my case Chrome
These are the first two messages which tell us:
- image not found on line 106 ā false
- line 107 runs into a fatal error as the image is not found
Warning: imagecreatefromjpeg(backgrounds/../stickersPWS/backgrounds/blue-sky.jpg):
Failed to open stream:
No such file or directory in /hosting/www/meteobellvei.cat/public/stickersPWS/sticker.php on line 106
Fatal error: uncaught TypeError: imagecopy():
Argument # 2 ($src_image) must be of type GdImage,
false given in
/hosting/www/meteobellvei.cat/public/stickersPWS/sticker.php:107
This is how a ānot-an-image:ā looks with inspect
Yes Wim, in fact the warning issues that Iām going to fix are all referred to color profile of the .png image.
They canāt create a fatal error.
By the way, in the next release the color profile image warning will be fixed.
Regards
Antonio
I put it like this and it doesnāt work eitherā¦ I thought that putting the same route as the fonts would work, which is how it was until now, but it doesnāt work in either route.
thanks for the help you are giving meā¦I donāt know much about programming
And as you can see yourself, that flag is not in the flags folder.
The script thinks that .cat is a country as pwsWD allows you to have a Catalan flag in its data.
For the sticker.php we need to create a cat.png to add to the stickersPWS/flags/ folder.
Sadly that needs to be a .png and the Catalan flag in pwsWD is a .svg.
Will take some time.
To make sure we face no other problems:
First make a copy of any flag in the flags folder and rename that copy to cat.png
Then https://www.meteobellvei.cat/stickersPWS/_test.php should work
or we face a new problem
After it works with a dummy cat.png use the attached cat.png to check if that works.
succes,
Hi guys!
Thanks for the help. Iāve already put a flag cat.png in the Flags folder as seen in the image, but it keeps generating the error and the sticker doesnāt show upā¦ Iām pretty lost and canāt quite figure out what the problem is.
Sorry, new error on line 186 missing station-icon /station.png.png
Have to check that.
The error is caused by a change line 23 in your setup.php
Can you ,please post that file, maybe there are other errors also.
That line should read
'station' => "station", // jpg icon of your station. You can chouse or upload one in station-icon folder (if you upload a new one you have upload 2 icons one black and one white)
That is the problem.
yes, thatās exactly it! bufffff Iām really sorry, but there are things that are messed up in the setup configurationā¦like why the fonts have to be given all the folder indications and here they donātā¦or why the background has the .jpg extension and the station logo doesnātā¦ ā¦ Thank you for your patience, Wim.
All scripts on-line are free-ware or donation-ware.
They are often developped first for ones own use.
But when other station-owners see them they are also distributed to others.
They are often upgraded based on new user request and new ideas.
Succes with your website and scripts,
Hi, did you see the readme.txt file inside the stickerPWS folder?
Regards
PS: Sorry, I saw just now that it is not clear for a newby. Iām going to rewrite it better in the next release.
I understand it perfectly WIM!!! once implemented I will proceed to make a donation to the author. he deserves it for the work he does
thanks Antonio, and a last thing. Everything works correctly, but when you try to put in wordpress or blogger the image of dynamic_sticker.php is not displayed. In chrome it can be seen, just like all the stickers, but the dynaic cannot be set as an embedā¦any idea what it could be?
Hi, new version is now available. On top of this topic there is the changement list.
Enjoy it, regards
Antonio
Here you can see the dynamic_sticker working into wordpress 6.5.5
