Weather Report Formatting
I don’t think this is a bug, but probably just something I’m not setting up correctly…
For some time now my emailed weather reports come in without any formatting… like this:
[color=Blue][i]Weather Report for Hemet, CA. 92544 as of 08:00 AM, DATE: October 25 2004 More Detailed information is available at: http://www.hemetweather.com/weather/default.htm weather: NOAA - mostly cloudy - mist PC - Fog Temperature: 51.5
If you’re using a custom weather report - typically from customweatherreport.txt - use the tag
 before the tags, and
afterwards.
do you have the use html ticked stuntman
but yes gary is right, if you created your own custom report, you could add those tags
its not normaly like that
