Since I installed a newer version of WD (for Windows - full install file) in August, my Weather Report Email always shows a max and min temperature of zero. Other values seem unaffected. I have tried re-installing again (currently 10.37S 149) but the problem is still there. Does anyone have any ideas please? Is there a template for the email that I can check/tweak?
This is a copy of today’s email report:
CURRENT WEATHER REPORT FROM: Hollingbourne Weather
Conditions: Dry
Temperature: 20.7 C
Trend: -0.4 C /hr
Average windspeed: 0 mph
Current speed: 0 mph
Direction: ESE
Barometer: 1008.9 hPa
Pressure trend -0.4hPa/hr
Humidity: 84 %
Dew point: 17.9 C
Todays rain: 1.8 mm
Monthly rain: 6.4 mm
Yearly rain: 355.6 mm
Maximum temperature: 0.0C at time: 5:01 PM
Minimum temperature: 0.0C at time: 5:01 PM
Maximum heat index temperature: 21.1 C at time: 5:01 PM
Minimum temperature: 16.9 °C at time: 1:01 AM
Maximum gust today: 13 mph ENE at time: 9:01 PM
Max gust last 10 mins: 3mph
Current Windchill: 20.7 °C
Soil temperature: GrHse 19.4 °C
Lounge temp: 23.2 °C
Lounge hum: 60 %
Solar radiation: 21.0 w/m2
Sunshine hours for year: 867.3
Sunshine hours for month: 65.5
Sunshine hours for day: 1.7
This is a daily report of today’s weather in Hollingbourne, Kent.
Live weather can be seen at http://www.hollingbourneweather.co.uk
Created by “Weather Display” version 10.37S149 18:10:42 17/09/2023
Time of Weather report: 18:30:03 Date of report: 17/09/2023
You may have other problems too. An average wind speed of zero for 24 hours seems unlikely.
Are the max/min values correct in your clientraw files? That would at least tell you whether it’s an underlying data problem or something related to the production of the daily email.
Yes - the values are correct in the clientraw and clientrawtemp files.
I have had other issues too though recently - the main screen has kept flicking to blank graphs and zero values every now and again, then returning to normal.
I don’t think there is a template for the daily email report and as the underlying data is correct I think your only option is to email Brian directly to report the problem.
i think the default report in 149 has issues
here’s mine
CURRENT WEATHER REPORT FROM: Ballaugh W6 Unit
Conditions: Dry
Temperature: 13.9 C
Trend: -0.0 C /hr
Average windspeed: 6.5 mph
Current speed: 7.1 mph
Direction: E
Barometer: 1017.6 hPa
Pressure trend -0.3hPa/hr
Humidity: 93 %
Dew point: 12.8 C
Todays rain: 3.6 mm
Monthly rain: 47.6 mm
Yearly rain: 611.8 mm
Maximum temperature: 0.0C at time: 17:52
Minimum temperature: 0.0C at time: 17:52
Minimum temperature: 11.1 C at time: 06:00
Maximum gust today: 27.6 mph NE at time: 10:43
Max gust last 10 mins: 10mph
Current Windchill: 13.9 C
Snow for season: 12.0 cm
Indoor Temp.: 24.8 C
Indoor Hum.: 66 %
Solar radiation: 0.0 w/m2
UV: 0.0
Sunshine hours for year: 1258.2
Sunshine hours for month: 112.0
Sunshine hours for day: 0.4
Created by “Weather Display” version 10.37S149 09:28:03 16/09/2023
this my build 145 to compare
CURRENT WEATHER REPORT FROM: Ballaugh W1 Unit W4
Conditions: Dry
Temperature: 13.9 C
Trend: +0.0 C /hr
Average windspeed: 8.0 mph
Direction: E 101
Barometer: 1017.7 hPa
Humidity: 93 %
Dew point: 12.8 C
Todays rain: 3.6 mm
Maximum temperature: 14.3 C at time: 17:52
Indoor Temp.: 24.9 C
Indoor Hum.: 64 %
UV: 0.0
Sunshine hours for year: 1157.9
Sunshine hours for month: 80.4
Sunshine hours for day: 0.0
Created by “Weather Display” version 10.37S Build 145 19:46:47 13/09/2023
That seems to be exactly the same problem. I wonder if it’s related to the main screen flicking issue? It happened for me when I installed build 149 too.
The flickering screen coincides with the screen capture and is less noticeable if the main screen is at the default size I customised my main screen size recently and it became noticeable this applies to b145 and b149
The screen actually loses all graphs and data for a good few minutes, rather than just the momentary flicker that occurs during the screen capture. Having said that, doing a full re-install seems to have stopped that for now . . .
Are the graphs fully up to date when that happens, i.e. no missing recent data? I’m just wondering whether WD is reading the history from your station when this happens? Others have mentioned that WD seems to go to sleep when it’s reading the history which sounds like what you’re seeing.
