Weather Display on Iphone/Android?
I cannot get the new version to work at all, i renamed the settings file but its just not grabbing the clientraw data like the old version did
Did you rename iwdl_settings.js.sample to iwdl_settings.js and edit the iwdl_settings.js file?
Make sure the clientraw_dir is set (like in the original settings file).
What is the link to your iwdl?
Sietse
Sietse,
All I can say is WOW!!! I’m totally impressed with your iPhone sudo APP. My wife just got an iPhone last month and I’ve been giving her page after page to try to get her to see our weatherstation when she’s away from home; however none have been as impressive as yours. I’m also really impressed with ease of implementation, from the time I clicked download of the “iwdl-0.7.tar.gz” file to uploading exploding it, including my configuration was done in a matter of seconds.
Thanks a ton for a fine addition to my site http://www.lakemaryweather.com/iwdl
I’m having two Issues with your current 0.7 version:
1> My WinDir shows to be a numerical value “12.224 in” and not a true direction, also the graph seems to be also be numeric; however my setting for windir is “abbr”.
My current setting are:
settings[“temp”] = “f”;
settings[“wind”] = “mph”;
settings[“wdir”] = “abbr”;
settings[“rain”] = “in”;
settings[“baro”] = “hg”;
settings[“height”] = “ft”;
settings[“time”] = “12”;
 settings["lang"] = "en";
2> Neither her or I are able to press the “Setting” or “About” link on her iPhone to get them; the “Map” link is hit or miss too (and her fingers are small and mine are big so that’s not the issue )
Please help at your earliest opportunity…
2 small issues
http://mobile.cnyweather.com
Also wind direction shows as x.xxx in. and I cant get ride of the main screen where the title says “Weather Station”
Tony
Sietse
I’ve translated the new iwdl_lang_no.js file. www.servicesenteret.as/weather/iwdl/iwdl_lang_no.js
There is one problem though - the wind dir abbr on the first page shows the caractercode for the Norwegian letter
Sietse,
I have installed V0.7. I have also done a new Norwegian language file with the new entries. I see that you have chosen not to use my translation in V0.7. That’s fine with me, but I’m using my own translation file on my site.
A couple of problems: You have started using the station name as a header to the screens. Mine seems to be to long. What is the maximum length? You can check it at iWDL Then I have the same problem as others with the map. I just het “Unknown location”, even with the new all.min.js that you posted Do you know why? I have not given the position in the settings-file, but it’s in the clientraw file.
Sietse,
I also notised the problem with the letter
Hi Sietse
With your new file the problem is solved. Absolut great, it looks very good.
Hermann
Sietse
The map page works if i put the position in the iwdl_settings.js file, but not when pulling the position from the clientraw.txt file.
Ole-Chr
The same thing here.
I finally reproduced and solved the map problem; if the coordinates are in the clientraw.txt, that will be used now. If not, then it will try to read it from settings.
Also the issue with the wind not showing the abbreviation (to be more axact: those who use inches for rain) has been resolved.
And the Norwegian translation should show correct wind directions (however, it might re-introduce the 2nd line disappearance problem).
The latest is now 0.7c, if you have 0.7 already installed, please download http://sietse.net/iwdl/all.min.js and http://sietse.net/iwdl/index.html , and install in your iwdl directory.
Latest version download: http://sietse.net/iwdl-latest.tar.gz
Sietse
Excellent work, its working well now thank you…
Anyone who dont have an iPhone but would like to test it to see what it would look like on an iPhone then please see this site http://www.testiphone.com/
That means that your weather station name is not set, please have a look at Weather Display Live - Support
Sietse
Where does the map get the city location from? The google map pin is exactly correct
with my location, but I believe the “city” listed is my ISP location
Sietse,
I can confirm that the map problem is fixed. And the Norwegian
That is wat Google tells me; maybe I will make an entry in settings to override the google guess.
Sietse
Thank you very much! 8)
Everybody,
In the latest version, 0.7c (http://sietse.net/iwdl-latest.tar.gz) the toolbar should be easier to tap.
I have created a new thread here: Weather Display Live for the iPhone and Android because this thread does not belong in this forum (WD Questions).
Please do not reply to this thread anymore, discussion on iWDL continues at the new thread.
