Weather Display Main Web Page code
If you have a look at the code of my Weather Display generated web page, I have the tags and a few times in the source. Do you have the same? http://users.skynet.be/oster/meteo/Oster_Manhay.htm . Cheers.
Hmmm yes you have indeed. HEAD should not be within BODY.
It looks like you manage your own datahtm0 code?
If that is the case you can remove all or after the tag in that code.
But if you are not managing datahtm0 yourself then Brian will need to have a look.
cheers
In fact I have these settings. See attachment.
ah ok so you are not managing datahtm0.
Brian will have to look and see why the coding error is being produced in the default page.
