Weather Display issues - Can't post webcam
Right, how to explain this, let me start at the beginning: I am running Win 11 Pro, and have the latest version of WD I’ve got problems firstly with WD glitching and pausing regularly for about a minute at a time. Following that I have configured WebCamCapture, and that is generating images that are saving to disk. However no matter how I set up the inbuilt FTP I can’t figure how to upload those files. I have setup everything I can see to deal with that issue. the file I am saving as is a_cam.jpg and a_cam.gif. I could obviously write a script to do this with another FTP client but that defeats the object I don’t need two ftp clients open at once. incidentally although neither matters these are supposed to upload to https://mm0zif.radio/current/WX/ which is running PWS. (but that is irrelevant as nothing is getting uploaded) Also everything else from WD is getting uploaded.
so have you tried ftp/internet setup web cam upload failing that try ftp/internet setup general ftp functions
Sorry I sort of left you in the lurch on the other forum… had a rough week.
Just to verify, your webcam set up looks something like this, correct?
The freezing concerns me though. You said it started right after you started using the wdwebcamcapture program, right?
