Weather-Display FTP
Hello
I’ve had to change PC’s and setup WD again. clientraw files are uploading but not all the data it appears the status page, if that makes sensce.
Any suggestions please?
Chris
Check that all the WD switches related to uploads are turned on, e.g. the Main Internet switch.
Yup. Still have issues. I’ve email Brian as well
Hi All
Can anyone recommend an FTP program that automates transfers to a server for webfiles?
I’m trying to figure out WINSCP but can’t seem to find where the automation part is.
Many thanks
Chris
This might help - Schedule file transfers (or synchronization) to FTP/SFTP server :: WinSCP
I don’t know of any other solutions because I only use either WinSCP or the command line tools in Linux (sftp, scp, etc).
I take it you have checked the new computers firewall is not stopping the ftp program from working
Yup I did. It’s a bit frustrating with WD as it works sometimes to upload files and then stops. At the moment I can’t get WD to upload a file from StormVue3 and the 4 files needed for WXSIM forecast
The FTP log is usually pretty detailed about what uploads were attempted and any error messages. Are there any clues in that log?
It’s very random. At the moment it’s showing files being uploaded. So now that I have that sorted, ish, I’m looking now at the StormVue3 script and trying to sort that out. I have attached the config file.
config.zip (574 Bytes)
