Several times during the past week Weather Display has been crashing.
there is someone else reporting a crash with that weather station type, the w2010-13 dat alogger
(which looks to have developed after I fixed the time from the data extraction)
it looks like its a list index out of bounds error
try the beta/debug version, which should produce a detailed error report, and email me that report findings
thanks
have you installed any other software recently?
first.
What time did it crash, do you have databack set to “On”?
there are a few more people with a ws2010-13 data logger that are having trouble
i wil have to try and see if i can capture a crash here
(but also try the beta debug version that will then provide more information to me)
Are you running a Virus scanner ??? I’ve had it do this several times when my Virus scanner AVG Pro was doing a full scan
Hi… I am getting the same problem - I have a Davis VP and have not installed any new software (except newer versions of WD) it always seems to stop at 23:59. The PC is left unattended all the time - in fact I am not home very often at all!..
It will crash 2-3 times a month.
this particular thread is about the ws2010-13 data logger, and a problem I have introduced, which I am working on at the moment
(i had 10.19y going ok today for 6 hours (until I accidently closed that test program down and then stuffed up my soak test)
i have it confirmed that a new 10.19y, ready now, looks to have this fixed
please try that
thanks
I’m still having a problem.
i have been working with a few other people on this issue (via email)
and the beta debug captures it as a list index out of bounds
I have been trying to narrow down and fix where exactly that has been occuring.,…
on another thread, 2 people report a new 10.19z is OK
so I would download a new 10.19z zip version
bad news Brian,
working with 1019z I had a view crashes, can’t capture when it’s exactly happening.
I only can see in my taskbar, when my mouse roll over the icon, it disappears.
Starting up WD I can see it happens hours ago after that the maingraph shows something like this time sets:
http://www.geocities.com/edje1205/WeerpaginaZaanstreek/edsweather.gif
back to 1019s no problems till now and I’ll watch it from now on
have a look at the other thread on this:
its ok now , 10.20b
hi Brian,
I’ll download it now
and watch it comming days.
Thanks for notifying as allways he.
How’s mum now with all your work on this
let those guys leave theire computers alone ?’
my faster internet connection helps me spend not quite as much time…and its not so fustrating
let me know how it goes, but I have it confirmed I finally fixed this ellusive problem #-o
