Weather dials
Just something I have noticed on my weather dials screen.
The heat index scale on the right hand side seems to be out of whack (in this case only going up to 20 when the value is higher.
But strangely enough after I had viewed the dials screen the scale suddenly changed to 20 and above although the min/max pointers are inthe wrong place.
Also would you know why my average wind speed pointer is flashing yellow and red?
Attached are pics showing the heat index scale with a simulated animation of the flashing pointer!
Not worried about a rush to fix it - just curious about it.
ah, its becuase that dial is shared as the windchill…and so the scale changes…
but instead i will have 2 dails, and hide one or the other
that will be better
This isn’t connected with my issue on Apparent tmps is it?
Also in the questions thread…
http://www.weather-watch.com/smf/index.php?topic=4964.0
no…
i have been watching my apparent temperature gauge on the extra dials, and its always been correct with whats on the main screen.
maybe email me your settings file, wdisplay.ini
