Weather Display Ver 10.37S144 on Windows 7 SP1
Now I notice that I can not connect to my MySQL.
It says Error. Out of Memory and date and time.
I incresed the ram and swap.
It does not help.
It has been working for ages. And now …suddenly…
Any advice ?
That is correct. I run the WD client on a Windows 7 and I have mysql that I store all data on which is a an Ubuntu server. And the error appers when the windows is trying to send data to the ubuntu server.
Plenty thx for your support.
I will try to upgrade my WD! There can not be any harm done by bringit forward for 3 years.
This since I think the issue is at the wd side.
I keep forgeting please… tell me what is the proper and good fashion to to upgrade my current wd. I do not want to lose data like all my history. Was there not a wd.ini or something that needed to be saved. Allso, where is the settings saved. I do not want to reinstall my weather station.
Plenty Thx for the update.
So there is no zip update. This is a full install then ?
Then I need to be carefull regarding my history and settings.
History are saved in wdisplay.ini (history of altime high and low from my station)
But what about sftp and mysql setting and so on…?
I do think that that page you are so nice to point out for me needs some more work but that is since I am rather daft.
Yes You are right but not now. Now I want to get this to work.
Yes ! I have both that and a snapshot of the old WD.
So now I turn everything off. No WD Client running and replace the wdisplay.ini ?
Is that it ?
Corret ?
I turned off the Weather display by doing exit in the menu.
I waited and checkt that there is no other applications running.
When that was done I replaced the wdisplay.ini with the backup that I have.
I then restarted the applikation with Admin priveliges.
That did not help.
Looking at the All time records it will not change.
Crap ! I do not habve time for this now.
Any advice?
