i have a linksys SLUG (NSLU2) that i have rebuilt to run debian with apache
this works fine but being an embedded system does not have X installed, hence no GUI so i downloaded the Linux Console only version
however i can not see now what else i have to do !
the config.txt file does not list the WXT510?
and there appears to be nowhere to configure which com port i am using ?
i assume then that i run Gowdconsole.sh ?
i would need to add support for that station type first…which I can do
second, you just set the port as U
and it then it will use tty.USB0
(it should say that in the config.txt, or at least I did post that info in the original NSLU2 thread (have you see that?)
sorry it’s just that the latest ver now has
Weather station type=60 // Irox=59,WMR100=232,WMR968=8, Davis VP=31,Davis WMMII=4, WH1081=166, 2310=60,WXT510=190
thats the consolewd program for a normal pc
and no the special slug version
(i.e compiled for a ARM type processor)
you cant use the normal PC version on a slug
to replace the executable file to where you have wdconsole installed
(and rename from projectslug after unzipping to consolewd)
(and set the station type to 190)
