WDL Version 1.07 Released
Two versions in one week - must be something wrong with me! :smiley:
This version has sliding temperature scales. I’ve reduced the scale from 65 degrees C to 50 to improve the resolution but the temperature range is now capable of displaying from -50 to +60. It means the maximum extremes that can be shown in one day is 50 degrees but hopefully no one is living in an environment like that!
Also added gradient to UV bar as requested.
No need to update WD beyond that required for 1.06 (10.12v) or change config file for this one.
Julian
keep up the good work Julian!
all updated here ok, works great (i just updated the flash move file and my index.html with the change of the flash file name, and that was it
easy)
Thanks for the coloured uv bar. All works excellent.
Hi Julian
Do you think you could include a build number on the WDL page somewhere. This may prompt those that have older versions to upgrade to the latest.
Geoff
good idea
i am also going to do a new wd newsletter soon too, and promote wdl more
Yeah, I’ll try and find room for it somewhere on the next release. :slight_smile:
Julian
Both mention that they are only effective about 17 degrees Celsius… is it possible to change that text to degrees Fahrenheit if that is the unit chosen?
Thanks!
If you choose Farenheit it should show F as opposed to C. Or am I misunderstanding you?
Julian
If I choose Fahrenheit it does show the correct readings… I’m talking about the “Hover”… if you hover over the humindex there is a popup box that explains what that particular measurement is… the popup in this case states that Heat Index/ Humidity index is only effective above 17 C… what I was suggesting is that the text show 63 F in that explaination if the units are F, and 17 C if they are Celsius…
Does that make sense? It’s not a biggie, just something I noticed and I wasn’t sure you were aware of…
Thanks!!!
Ah that makes sense. OK will fix that next release.
Julian
