WDL Ver.3 Webcam
I can’t get my web cam to display. It is a jpg file and I think I have everything set right. I can get other jpg files to show on the webcam. Any idea’s.
I think it’s because it’s a ‘progressive’ jpg format. I resaved it as a normal jpg and it loaded fine. The file size also went from 56KB to 4KB (although that’s probably because it’s night time and the image is mostly black).
Julian
Thanks. I found if I create the jpg with WD then it will load.
Dear Julian
Any luck with a hyperlinkable webcam button option or a hyperlinkable button on the low resolution webcam pop-up we can use to invoke our higher res cams yet?
BTW The graphing and everything achieved by you to reach this point is truly awesome Julian!!!
Thanks so much
gk
