WDL Domain nimble
HI Julian,
Any chance of making WDL nimble enough to allow either a http://www.domain.com or http://domain.com url?
I have 2 domains, domain.us and domain.com. Same domain name, different TLD. What would be the cost to license the 2 domains? Any break on the price?
Randy
KK6RW
WDL works by converting the domain to a number and validating that so if the domain was different, ie with a www prefix, it would expect to see a different number. I don’t mind giving you an extra serial number in a situation like this where it’s clearly the same domain but getting WDL to automatically understand it wouldn’t be easy without changing the way serial numbers are generated.
You can work around this with html though. Simply look at the page referrer in javascript and if it’s not from say www.myweb.com simply redirect the request to the correct page.
Julian
WDL works by converting the domain to a number and validating that so if the domain was different, ie with a www prefix, it would expect to see a different number. I don't mind giving you an extra serial number in a situation like this where it's clearly the same domain but getting WDL to automatically understand it wouldn't be easy without changing the way serial numbers are generated.
Julian,
I’ll do the redirect, it’s easy enough and won’t require you to change serial number generating coding.
Randy
