Wdisplay.ini gets corrupted after reboot
Like the title says… and it takes extra 1-wire sensor info with it. Frustrating. 9.46a
Tom
i dont have that sort of trouble with windows 2000
but i know the use of a good old fashioned text based ini file like wdisplay.ini is not so good on XP…in that the data is kept in memory instead of being written to the file…or something like that,…make sure you go save and exit, as then a update command to the ini file is done…
also, check to see if the settings are being saved on the fly…
Check settings on the fly by viewing the .ini file?
Tom
