When I have to close WD for upgrade or reboot etc., I always have missing data in the graphs for Indoor temp and Solar (which I have plotting instead of indoor humidy, blocked in) upon restarting WD.
The Indoor temp is always reset to 68 degrees F until the next data retreval.
I have been unable to sucessfully edit the logfiles or use the correct graphs feature to fix these issues.
The note at the bottom of previous post was not intended nor necessarily apply to Wdisplay…sorry if it came off that way…mostly I am quiet pleased with your software.
I am having problems with a new HP printer which uninstalled itself this mornning and now I can’t re-install it…it gets about half way through then backs itself out and sayes try again… uninstalling it still leaves files and registry enteries.
I had a similar problem with a HP printer, visited the HP website, and downloaded an uninstall utility which removed the debris, and allowed a new installation. Worth checking. :?
