Yes and this setup produces a texttags.php file with just one value 24.33% and a wxlocal.html with just this tag “%moonphase%”
so that we are on the same page, if you could email me your config.txt file
as I am not able to duplicate this problem with vers 17.1
Ok Brian
here is config.txt…
I said to email the file
not sure why you would post it on a public forum for anyone to download (as it contains passwords)
I suggest you delete this asap
I have deleted the attachment.
Not a big deal Brian, it is just an ftp user with limited rights. But will change it never the less…
Regards
Manos SV1IW
also though your WU ID/pass was there too
anyway, I have tested and its OK here (linux desktop)
vers 17.1
I could test on my Raspberry pi 1/2 or 3 next
Ok I will change it although it’s useless for anyone else but me. Please note that I use a Raspi 2, I am not using a Linux Desktop here…
Regards
I have tested on my raspberry 3 and its OK with that too
have you tried deleting the testtags.php file?
Brian yes, I have deleted the file and the one produced is again useless. I suspect that there is something in my testtags.txt that the new executable doesn’t like. So I suggest either to send me a testtags.txt that you know is good or to send you my testtags.txt and try it to produce testtags.php from it What ever you think is best…
but I am using the testtags.txt (renamed as wxlocal.html) that you sent me
and its OK
you could try though deleting (and saving) chunks of code from the template file until you hit on where the problem is
Ok Brian, I will do so, I may also try a pi 3 which is the only thing haven’t tried so far.
Regards
Manos SV1IW
OK, I will look at adding those as well just need to find the spare time currently busy planting native treesI have now completed stage 1 of my native tree planting project (9000 native trees, that I grew myself, took me 2 months of hard work (with some help) stage 2 next year, rinse and repeat
