I’m getting this error when I launch GoWdconsole.sh. I’ve commented out the root checks, so it’s not a permission problem. It reads thru/and interprets the config file, shows this and dies. Weather Display vers WD console 5.4
If use this program,then please consider sending a PayPal donation to [email protected] (Brian Hamilton)
to help with costs, and support, thanks! www.weather-display.com
An unhandled exception occurred at $00B9E721 :
EAccessViolation : Access violation
$00B9E721
$009E257E
$08060B10 main, line 6271 of consolewd.lpr
I can’t run the full version as I don’t run X. I tried to run it a while back but ran into huge library problems and determined it wasn’t worth the trouble. I’ve been using another tool to get data from my Davis WX, but want a clean creation of clientraw.txt…so here I am again.
Trying again…anyone have any ideas on how to get more data to help figure this out. Since we’re leaving out the X-QT stuff…this should be a simpler…but the error doesn’t give me anything to go on.
I appear to get the same error message and posted a request for help a few days ago, so far to no avail.
Can anyone shed any light on this? I equally do not want the overhead of the full XWindows stuff, the PC I am using is a Viglen MPC -L, it is about the size of a CD case and costs about
Thanks Brian.
I downloaded the lasted version on the site and got the same line # Weather Display vers WD console 5.4
An unhandled exception occurred at $00191721 :
$00191721
$00D9057E
and remove the .dat from the end (and download to where you have the program allready)
and then also delete the wdconsole.ini file and config.txt file
to start over
Here is what I get in 5.5 Weather Display vers WD console 5.5
$00B9E721
$008F857E
$0808458A main, line 16152 of consolewd.lpr
Do I need to delete config.txt or wdconsole.ini at this point?
OK…that’s going to take me a little longer.
Since…I had X problems…and couldn’t get the console only version working…I built a VM running Windows and bound my WX serial port to the VM. I’ll need to undo that later tonight and retest.
OK Brian,
Here is what I got. The line # 16152 is the same, but the unhandled exception is different. Is that more what you’d expect?
I am very confident that the app has access to the serial port:
1…I’m running as root.
2…I removed the check in GoWdconsole.sh
3…Another WX package can access the WX on this port.
$00B9E721
$00F5057E
I specify my Vantage Pro 2 like this “Weather station type=31”
and /dev/ttyS4 as Comport number (e.g 1)=4
It is an add-on 4port serial card.
I’ll try the other libcom.so a little later today.l
i will do some testing here to make sure it still works OK
but also try the libcomold.so file (i.e rename that one to libcom.so (rename libcom.co to libcomnew.so first), in the deploy folder
Brian,
RRT4 pointed an error I was making when referencing my serial port. I’m in the process of backtracking if that was my problem all along.
I assumed I just needed to lop off /dev/ttyS to get my com port #…but that wasn’t the case.
I have it running now, reading up on what it spits out. A lot of *****Received count…interspersed with weather data.
just checked on the format of the original config.txt
all you need is the number after the = and before the //
(i.e check the default config.txt with the downloaded files)
