I mean you click on any of the buttons in the Control Panel and they do nothing. I can click on ok or cancel to exit out and that is it
Then I tried to click save and exit, and that didn’t even work.
Thought I would go back to 307 and then I really messed it up. Had to grab the ini from a previous backup. WD is in the process of a Davis VP history extraction.
see if there is an error under view, program event log
do not go back a version if you had to set to create the extradials.gif (as that was creating an error)
if you do want animated individual dial images then make sure you have ticked Animate the weather dials/large display/individual dials image’s (last 6 minutes, 1 minute interval records)
in control panel, webfiles/web page setup
error with file #4 Access violation at address 01507EEC in module ‘WeatherDisplay.exe’. Read of address 00000430
error with file #4 Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298
ERROR: Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298 System.SysUtils at time/date 21:36:50:640 06/01/2016
ERROR: Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298 System.SysUtils at time/date 21:36:59:211 06/01/2016
Cannot create file “C:\wdisplay\webfiles\Zumbrota Weatherdial.gif”. The process cannot access the file because it is being used by another process
ERROR: Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298 System.SysUtils at time/date 21:37:46:285 06/01/2016
ERROR: Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298 System.SysUtils at time/date 21:37:59:497 06/01/2016
ERROR: Access violation at address 0104257A in module ‘WeatherDisplay.exe’. Read of address 00000298 System.SysUtils at time/date 21:38:42:606 06/01/2016
I wonder if the errors were from 307 when i reinstalled it after the 308 lock up.
Are the Control Panel buttons failing to work for you after you click on a couple and exit out of them? Bld 308
( Running Bld 308 = The lock up started after I went into Internet File Creation & Uploads, then went into Web Files/Web Page. Then after that I would try and click on any of the buttons with no action. I could click ok to exit. It looked like everything was working fine so I was going to exit and save and then that wouldn’t work.
Then I noticed VVP, Cumulus and Weatherlink were not responding. Could WD have started sending garbage back through?)
I’m back at bld 307… Since it is 10:15pm here. I will try tomorrow evening to upgrade to Bld 308 and see if the extra gauges work.
Sounds good on the animate. I will go back to the 5 minute interval.
Updated to Bld 308 and all is working. Must have been a odd glitch. Extra dials seems to be aligning properly. Only displaying apparent temp. Thanks for your assistance…
