On 2/21 I started WD QT4 10.37k-b00 7:24 local. I downloaded b01 and installed it 2/25 and started at 17:52 local. On startup the data logger is suppose to start the download and continue to the most current time, in this case it start the download at 2/23 - 23:05 and stopped downloading at 2/24 17:52. It over wrote the logfile with just the information downloaded and WD continued as normal.
I have also noted one to hangs against the serial VP 2 data logger and noted that data was still coming down the serial line but WD was not receiving – the data light flashed green/red and the data quality light was solid green and no change to any data was taking place. The hangs last anywhere from 5 minutes out to 40 minutes with the build 00. I will see what happens with build 01. I did see one run of Access Violations in the console log file.
Again, I think the interface is cleaner and the release much more stable.
Brian, note on the CWOP setup screen at the bottom there is a checkbox that does not show up and screen will not resize to show.
On initial startup the testtags.php file was being created and was not uploading until I went to the Customize page screen and resaved it. Once that was done the uploads started every 5 minutes.
Keep up the great work.
Mike - N7DQ
