WD MQTT to Home Assistant won't stay connected
Brian,
I think I figured out the problem. I should of subscribed to WeatherDisplay/json. I had copied Renato’s setup that was also using this subject WeatherDisplay/temphum along with the WeatherDisplay/json(Which I was using as the subject in WD).
My bad #-o :oops:…You deserve the pat on the back. Nice work!! Someday I’ll figure this out.
Added MQTT support
