WD migration from 10.37R Build 81 to latest build
Has anyone gone through such a migration and could share some thoughts about what to take care of, backup, move config files etc ? It’s been a while, WD was rewritten due to loss of code in 2014. Can I overwrite the existing installation with the latest files and still have it up and running without loosing anything or is there a step by step process required with in between versions ?
Krzysiek
Krzysiek
I simply copied everything from the .zip file to my WD folder and things worked just fine. It’s important to note that the program name is now weatherdisplay.exe so you may need to change some shortcuts on your system.
  • Jim
