WD lost configuration
WD has been working with no issues for years. Over the last few months twice for some reason I lost all my configuration and had to go through the entire setup to get back online. I have no idea what caused it but is there a log file or a way to restore the configuration and all the data back?
Ken
See Recovering Weather Display Configuration
You should have a data backup folder in the main WD folder in there are monthly zip files plus a .ini and .reg file
If the files pre date the problem then shut down WD then copy the ini file to the main WD folder and then double click the reg file this will reload it
If the files post date the problem the unzip the next to newest month file to get files needed
