I have been getting windows error sounds every minute, on the minute.
I ignored it but i have just formatted and installed a fresh system and i am still getting that sound.
When WD is closed, the alert doesn’t happen.
I tried closing wd’s webcamcapture software, it wasn’t that causing it.
So what within weather display would cause a windows alert sound to happen every minute at 00 seconds?
No error messages are associated with the sound.
Running WD .exe 43build.
Many thanks,
Stu
Unsure of that Brian, It’s just that one line in the log.
Do you want me to keep that screen open, clear the error and see if it reappears after 1 minute?
I’m at work at the moment, I’ll do the above later when I get it in if you wish.
ok home now,
Just done what was suggested earlier, it appears the windows bong sound doesnt relate to anything appearing in the program event log screen
its not doing it here
with your settings
(I let WD run for a few minutes)
maybe its your firewall or antivirus program or something else in windows that is not liking something you have WD set to do every minute
Would it narrow things down if i were to say when i start weather display,
the first minute that passes nothing is sounded, its only the second minute onwards that it has the windows sound?
I can rule out wdftp programs, realtime and wdcapture programs.
