WD Icon has bogged off!
Hi Brian
Not necessarily your problem this one but just in case…
I noticed this morning that the WD icon that normally sits down by the clock has vanished. It’s not in the hidden icons either. So I had a look in Task Manager and it’s not there either.
I couldn’t run it as a service as it started before the internet connection was established and that caused all sorts of problems so I start it manually now but it has been running happily for several days.
When I tried to start WD again it told me that it was already running which is what I had assumed as the website was being updated correctly.
Is this one of your doing or is it down to SP2 and Bill Gates again?
Cheers
which vers of wd?
as i have found and fixed a potential bug
also, check the file program errorlog.txt before restarting
also, do you run a virus checker…and make sure no power saving modes set or similar
Hi Brian
I think it it is Bill Gate’s problem.
Looks Like I’m running 10.18 F. I got it back by shutting down and re-starting it and so far it has stayed there:)
It’s my friend now and I didn’t like losing it.
Cheers
