Hello all,
I have been running WD for a while now and have only a few times when WD would carshes and have to restart/reboot the PC.
After I installed 9.97b the problem came more frequently, like 4-5 times/day. I tried installing 9.97d to see if it would solve the problem but it’s still happening.
Any ideas on what the problem is? If I need to uninstall WD and reinstall, what config files do I need to save so I won’t have to go through and do all the setup settings again.
I have the error file generated by XP I can email if needed.
Also let me know what config files I need to supply.
humm
i know i definatly fixed a lock up (but it would recover) problem in 9.97b for win 98 users
There seems to be a few reports of problems since 9.97b though…
but I have not had any …
now, what weather station type and what windows version?
oh and to start feszh, but keep you current data
try:
install to a new directory
then save a file there called 2wd with notepad.exe
then wd will start up like new there, and set it up to start recording , and see how it goes
then you can merge data from the old location to the new one…
Same problem here
Wd reboots this morning without any reasen
nothing in program error
lost my connections with sensors as well
(don’t know or its a battery prob the com port says its ok)
997d now see what happens
got now windsensor back
Win2k
Ed, how is that web cam reset working:
maybe that is causing your crash, at 2am…
jbreamer:
frist, start it up and set it up and see how it goes
then simply copy across the datafiles and logfiles folder and webfiles folders from the old location
Brian,
Yes. It started blank, out of the box clean.
I also renamed the old folder to XXX OLD and reinstalled WD so it would create a new folder. In this setup WD has also crashed.
I looked at Event Viewer under Application section and saw all the entries where WD has crashed.
Here are a few entries (or part of the entries):
This one is in more often…
Faulting application weatherd.exe, version 9.8.3.0, faulting module kernel32.dll, version 5.1.2600.0, fault address 0x0000d756.
This one was the last entry…
Faulting application weatherd.exe, version 9.8.3.0, faulting module weatherd.exe, version 9.8.3.0, fault address 0x0001b298.
Thanks again for your help in getting this solved.
