I upgraded from r281 to r286 due to the Control Panel issue but my solar percent always shows 0%. This results in the sky conditions always showing overcast (see screenshots below). I went back to r281 and solar % again works.
edit the wdisplay.ini file
when WD is not running:
[ws2000]
Solar sensor=
change that to 0 if it is not 0
save
then restart WD
(there are other threads about this solution)
OK…I will give it a try tomorrow because it’s currently set to 1. Does it matter that I have a Vantage Pro 2 station?
[WS2000]
Solar sensor=1
set it to 0 (default) and you will be OK
I set Solar Sensor=0 and things are working again.
Thanks for the help!
