WD 10.20x partially hung?
I’ve got a strange event that’s been happening on 10.20x
Go to http://www.diamondheadweather.com and you’ll see that the page hasn’t
updated since 11:45 local time, yet if you “click here for live weather”, WD is still
updating WD Live, and the wunderground data is still being received every 15 minutes.
The only thing I’ve changed was turning on the warning download feature.
Are you updating or downloading anything from HamWeather? There have been a nubmer of people saying that their uploads have stopped and a common thread seems to be problems up/downloading from HamWeather.
I can’t remember off the top of my head. #-o
I will check when I get to the station.
This first started yesterday around 2:00PM local (1700zulu), is that about the
same time for others?
There were some problems earlier in the day, but I think mine died between 1500 and 1900 yesterday.
check under view, program error log for any errors there…there might be an error with the weather voice or something
and check if you have not set to use custom web page or anything like that
Yes, if it’s the same thing that happened to me, checking the log file will show an error connecting to hamweather. Once I disabled WD from attempting to upload to hamweather, WD started uploading again. I see that hamweather is still “down”, You can get to the main hamweather.com page but if you try to access the personal weather page section of the site you just get 404 errors.
On the other hand one wouldn’t think that WD would be undone by this problem. I would think WD would time out on a fail to connect and then continue on.
The only entry is:
152: No server specified in URL
