when i run wd 10.17r i get this in Program error log.
ERROR: Unable to write to WDISPLAY.INI at time/date 18:20:01 26-09-2004
ERROR: Unable to write to WDISPLAY.INI at time/date 18:30:02 26-09-2004
ERROR: Unable to write to WDISPLAY.INI at time/date 18:40:01 26-09-2004
ERROR: Unable to write to WDISPLAY.INI at time/date 18:50:01 26-09-2004
check the wdisplay.ini file is not write protected/. read only, or in use or locked out by windows
(found in c:\wdisplay or c:\winnt)
and try a windows reboot
it don’t help i still get
ERROR: Unable to write to WDISPLAY.INI at time/date 20:20:01 26-09-2004
ERROR: Unable to write to WDISPLAY.INI at time/date 20:24:00 26-09-2004
I did what you suggesed list time - but after 25-30 min. the program crashed again. I has been crasing all the afternoon today. Before it was crasing it was only crasing down 1-2 times a week - and freezing all the windows, so I had to close down the computer - before I could start WD again.
Now it is only the WD that’s crasing - and I can restart it again without restarting the computer again…
I have trayed to go back some versions - but it dosn’t help.
ERROR: Access violation at address 006A2D34 in module ‘weatherd.exe’. Read of address 00000030 at time/date 21:29:13 26-09-2004
ERROR: Access violation at address 006A2D34 in module ‘weatherd.exe’. Read of address 00000030 at time/date 21:29:14 26-09-2004
ERROR: Unable to write to WDISPLAY.INI at time/date 21:30:00 26/09/04
ERROR: Unable to write to WDISPLAY.INI at time/date 21:32:43 26/09/04
ERROR: Unable to write to WDISPLAY.INI at time/date 21:32:44 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:47 26/09/04
ERROR: Access violation at address 00000000. Read of address 00000000 at time/date 21:32:47 26/09/04
ERROR: Access violation at address 0000010F. Read of address 0000010F at time/date 21:32:47 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:48 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:49 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:50 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:51 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:52 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:53 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:54 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:55 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:56 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:57 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:58 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:32:59 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:01 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:02 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:03 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:04 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:05 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:06 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:07 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:08 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:09 26/09/04
ERROR: Access violation at address 00691CC5 in module ‘weatherd.exe’. Read of address 00000047 at time/date 21:33:10 26/09/04
try running the latest beta version, as it has crash/error trapping, and it reports more info to help me…(click on more details, and then email me what appears there)
are you using the latest ftpupd.exe that comes with WD?
its now 7.40
as it does not access the wdisplay.ini file at all, becuase on some setups, windows does not like more than 1 program at a time accessing the wdisplay.ini file
maybe check your security settings, or a secrurity program running
