Brian
Since so many of us have UV and or Solar is there any chance of adding UV and Solar to WAP upload data. By the way this feature works very well.
Brian
you can create a custom wap…
just create a file call waplocal.txt, in the webfiles folder
and use the custom tags…
i.e make one from the current index.wml file, and then replace the current readings with the appropriate custom tags
then tick to use the custom wap
but, yes, i can add solar and uv if thats available
Either way works for me, custom WAP sounds like fun, I will give it a try.
Brian
I set up a custom WAP and I now get a compile error. Could you follow my links and look at the code produced and tell me if you see anything wrong. It worked perfect with the non-custom code. Now if I go back to original it still gets a compile error. I even went back to a earlier version of WD. Same compile error. I have the custom code in place now.
do you mean on your web site?
what is the url?
compare the output with the original format.,there might be something left out…
Go to the WDL link below and click on the WAP link at the bottom of WDL.
I want the index.wml to be uploaded to a different folder than WAP. How ca I do that? That is because it is a different area where WAP is supported.
Ottar
hi ottar
i will have to add that ability to a new release of WD…soon…
Hi, I had the same problem and i solved just with :
Controlpanel/ftp/general ftp functions/
Hope it help you
i have added this ability now to the wap setup section now
